Bad Tinsel Lead or Coil?
Umbra
Hobbyist & CA Tenderfoot
Greetings.
Earlier today I traded a few gift cards I didn't have much use for for a pair of Rockford Fosgate Punch HE2s (12"). I've learned a bit from these forums and brought a multimeter. Each sub is a DVC sub. All the coils measured an acceptable impedance, save one. One coil yields no rating at all from lead to lead - there's no continuity. I tried testing on the (what I believe to be called) tinsel leads as close to the cone as possible in case maybe there was a problem with the wires outside the cone, but no dice.
I posted here a couple weeks ago with some ailing subs that measured unacceptably for their impedance values and those you could hear rubbing when you pressed on them, with this sub that's no the case.
I ended up taking the pair anyway thinking it'd be an easy fix, but I'm no longer sure that's the case. Before I consider cutting this thing open, can anyone offer any advice?
Greetings.
Not much fixing an open coil typically. If there's not an obvious broken tinsel the coil is likely toast. You might try to pull off the dustcap and see if there's a break where the coil lead meets the tinsel, but on most subs it's buried under more glue than you'll be able to scrape off to repair.
Thanks, Garychoffmann, I'll keep that in mind.
It's not the type of sub/basket that can be unbolted, so I guess I have to slice between the top/dust cap? (Not positive about the terminology) and find out if it's severed. If I'm careful, can I remove the dust cap and replace it keeping the sub's functionality in tact?
Is the dust cap the surround? There's another post on the front page that goes into the type of glue/epoxy you can use.
The dust cap is the dome part in the middle of the cone. He's saying take that off and look down it to see if you can see a lead Is broken or torn, the cap can just be CA glued back on
Where does the dustcap end and the cone begin?
Here's a picture I just took:
http://25.media.tumblr.com/14e9e541dbf2e482ca18ffc2936352ad/tumblr_mvb0pjwiFy1r153evo1_400.jpg
Should I cut at the bottom of the dome, a little farther out where the dome material ends, or maybe somewhere in between?
I've also got some cyanoacrylate solvent.
UPDATE: I cut inward at an angle all the way around in the middle of that area between where the dome ends and cone begins. I pried it up unearthing the innards. The wire has cracked off of the leads on the inside of the cone. I hooked up the DMM to the wires and the coil's good! Presently I'm degunking the exposed wire and surrounding area with the solvent. I'll resolder the wires and I should be back in business. I just need a way to readhere the dustcap to the sub. Would a flexible super glue work?
That's why I said it really depends on the sub 😂
16
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
9
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
Umbra
Umbra
Long Island, NY
Umbra
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
