fire_mike 10+ year member
Like the title says, what do you all think is the best 6.5 comp set for $200 or less?
This.Look around for a set of HAT Imagines, they can be had for less than 200, sometimes brand new.
I've seen a few sets lately on DIYMA.
/threadThis.
If $200 is your budget, no one is going to argue for either of those two over the HAT's.Well poo. I have been thinking about Polk MM's and MA RK 6's, but now there seems to be another contender. I'll have to look into the HAT's. Any thoughts on the Polk and MA's?
Thanks for the info. I have read that about the HAT's elsewhere, so I'm not going that route. I've been searching the web today, and I am pretty much set on the ck6's. Now I'm just not sure the 100 watts from the powerbass will be enough. . .I am breaking in my set of HAT Imagine speakers. I have them running in component mode with tweeter mounted on door sails. I am not going to write a full review due to break-in issue, but I want to warn you that these speakers will not sound best in component setup unless you run them active or unless the tweeters are really close to the mid. The tweeter is definitely louder than the mid, something that a lot of reviewers interpret as "harsh tweeter". I can hear a lot of vocal cues coming out of it compared to my Alpine Type R speaker (even though, this is against HAT's philosophy). This set is meant to sound best in coaxial setup. This is why tweeter plays so loud I think. In a typical coaxial setup, the tweeter is way off axis and needs to play louder. But in component setup, with tweeter much closer to your ears than the mid, the tweeter becomes dominant. I don't think EQ can fix this, unless you can equalize the entire >5K range.
I bought these speakers with the intention of running active in component setup, and when running active, the aggressive tweeter should not be an issue because I can just turn it down. If you want HATs, either run them in active setup, or buy HAT Unity ($350) which have a crossover and tweeter that was tailored for component setup.
Unfortunately I live in a small town in AZ, and there are not a lot of options to go listen to speakers (without driving all over the state). I have heard the Polk MM's, and I really liked the sound of them. They seemed quite smooth and were able to reproduce the music well.
What I really want is good sq and a lot of volume. I don't need to have sq that would win me competitions, but I want to be able to hear the details of the music and I don't want to fatigue my ears on long road trips (I frequently make 4.5-12 hour trips).
That being said, I am now comparing the polk's to MA CK6V's. I like what I have heard from the Polk's, and I like the 94 db sensitivity. I like what I have read about the CK6's, and they seem like a better bang for the buck (even though they are priced the same as the Polk). I've read the ck6's like power - I would be giving them only 100 rms (not sure if that would be enough to make them shine). On the other hand with the Polk's being more sensitive, and having a 2.7 Ohm impedance, I think the 100 @ 4 Ohm amp would be plenty sufficient.
Decisions decisions. . .
I also like the Polks, and I do recommend them, but I have heard the HATs and enjoyed them more. Like he^^ said, get em if you like them. They get decently loud and stay clear and flat for what they are.If you've heard the polks, like the polks, have the power for the polks, are willing to pay for the polks
.......then it's a duck!
From the Imagine set manual:I am breaking in my set of HAT Imagine speakers. I have them running in component mode with tweeter mounted on door sails. I am not going to write a full review due to break-in issue, but I want to warn you that these speakers will not sound best in component setup unless you run them active or unless the tweeters are really close to the mid. The tweeter is definitely louder than the mid, something that a lot of reviewers interpret as "harsh tweeter". I can hear a lot of vocal cues coming out of it compared to my Alpine Type R speaker (even though, this is against HAT's philosophy). This set is meant to sound best in coaxial setup. This is why tweeter plays so loud I think. In a typical coaxial setup, the tweeter is way off axis and needs to play louder. But in component setup, with tweeter much closer to your ears than the mid, the tweeter becomes dominant. I don't think EQ can fix this, unless you can equalize the entire >5K range.
