best duel 8" sub with around 1.5kw?
  • 4
ChasingTimez
Chase
23
Ohio
Been looking to upgrade my Memphis mojo single 8' and need some recommendations for a dual setup.
Anything under $1000 can work and looking for around 1k watts
im running it on my RF Punch P1000X1bd and might get a second one if needed.
Adding another 8" sub of the same type, upgrading to 2 new 8's, What kind of space (placement) are we talking about? Getting another P1000X1bd?
It's a great amp but if you're changing everything up, might want to consider a single amp upgrade as there are a lot of great 2K-3K amps for that $350 price point that even a refurbished RF is going to set you back.
What I was looking at was this so I don't have to build my own box and also it's a 2012 civic lx with 50k miles
Memphis Audio MJME8D1 Dual 8" 3600w MOJO Loaded 1 Ohm Car Subwoofer Enclosure https://www.amazon.com/dp/B08GG84DG1/?tag=caraudiocom-20
Memphis Audio MJME8D1 Dual 8" 3600w MOJO Loaded 1 Ohm Car Subwoofer Enclosure Amazon product ASIN B08GG84DG1
Well that's 1 ohm, and so is your 1k watt amp. I would want 2K watts or a little more going to that Memphis setup, but a second amp of what you have wouldn't work. You're going to need an amp that will do 2k - 2500 watts @ 1ohm RMS.
Pretty nice. two 8's are better than one! Same great amp, essentially the same wattage split but would be fed to twice the surface area, powering two instead of one, should work very well!
If you really want to get going, throw one of these in the mix!
Amazon product ASIN B0BN2JLBQ6
You could most likely recoup the cost by selling the RF. Either way, looks like a nice setup!
Thank you I appreciate it
For $350 bucks plus Tax and tuned to 33HTZ, this is a no Brainer to be honest. Might even look at the 10s?
330
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
416
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
534
I hear ya. There are so many good deals on speakers too. My kid is 16, so loud is better than SQ. LOL... I really like the sound of the PPI...
15
922
872
ChasingTimez
Ohio
ChasingTimez
    May 24, 2024
    May 23, 2024
