Best way to connect 5 speakers to a 4 channel amp
  • 4
bridge the front channels if you can to the appropriate load,
bridge the rear channels to the sub if you can with the appropriate load
thats the only way id do it. you cant run the sub on the same channel as it requires different frequencies
you want to maintain left right separation or it will sound like ****
What speakers do you have?
What amp?
And what subwoofer?
If the speakers are svc 4 ohm I would wore each pair down to a 2 ohm load and then wire each pair on the first 2 channels. And run the subwoofer bridges on channels 3 and 4.
Other option would be to run the front speakers on the front 2 channels and run the rear speakers off head unit power.
Either way, the woofer needs to be on channels 3 and 4 by itself.
Run the components on the front 2 channels, subwoofer on channels 3 and 4 bridged. Run the JBL off head unit power unless you want to add another amp.
I sure did. Nostalgia is what brought me to this website, wondering if it still existed. I can still name some of the people and describe some of...
8
224
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
442
I hear ya. There are so many good deals on speakers too. My kid is 16, so loud is better than SQ. LOL... I really like the sound of the PPI...
15
763
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
799
nzfrank
nzfrank
nz
Beentown
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
