Better bang-for-buck than lithium?
Sounds like a 14v battery. 12v batteries rest between 12.8-13.2 and charge 13.8-14.4 over is not really good for them. So a 14v battery should rest around 15v and charge at what he is using. It's a 14v battery 16v charging system
The facebook post listed earlier from Juicebox said it's a Lithium Ion proto.
There are several types of lithium batteries and Lithium Ion is one of them.
Lithium Ion rests at 3.6v-3.7v and charges at a pretty standard 4.2v
Multiply that by 4= 14.8v resting, 16.8v charging.
In accordance to longest life possible, the minimum charge voltage should be 15.7v, not 15.5v.
Assuming the battery is allowed to reach it's full potential during that charge that is.
This type of charge cannot deliver 100% charge but also lithium batteries last a lot longer if they are NOT fully charged as well.
Keeping lithium within the 20%-90% SoC keeps them within cycle spec.
Keeping their SoC higher than 20% at all times has the potential to extend cycle life more and more.
Above 80%, possibly over 10,000 cycles.
However for Lithium Ion, cycle life isn't as good as LiFePO4.
Lithium Ion also has a greater potential of fire if something were to happen. Lithium Ion requires much more dependency to the PCB than LiFePO4 does.
So whoever they are using, they must ensure utmost reliability.
Nothing is fullproof though.. A recent Tesla malfunction caused an entire vehicles to burn to the ground using LiFePO4 and this isn't suppose to happen.
Lithium Batts are very customizable from charge rates, discharge rate,low/high voltage safety depending on the controller used unlike agm or lead acid it only defies the laws of dumbazz
9512 lol If you're in that realm of woofers, there's quite a good selection outside of those 2, but DD is a very good pick IMO.
2.5 cubic feet per subwoofer not total. Those X's require some room.
813
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
Eggroll
RingsOfSaturn>your music
Eggroll
Death Metal > Your Music
B-Sh0t
maylar
    Jun 2, 2024
    Jun 1, 2024
