Big 3 New battery terminals help. Newb here. Pictures inside.
  • 3
Alimoose
So I was ready to go outside and do the Big 3 Upgrade until I noticed different cables that I don't even know go to. This is in a 1999 Toyota Camry LE (4 cyl)
Do I just not even attach it to my new battery terminals?
Here is the new battery terminal.
This is the cables I am talking about on the Negative Terminal. They wouldn't even reach the new terminals if I wanted to cut them and put them in. They're too short. Do I even need them?
And this is the Positive Terminal.
Same concept. I don't know which goes which. Should I just ignore it all and just connect the alternator cable directly to the Positive Terminal and ignore the rest?
Let me know, thank you!
^ I certainly wouldn't upgrade them all.... my lord that'd be a timely and risky process. If you're using new terminals to connect factory wiring, many people just stuff it in one of the new terminals.... I didn't wanna risk voiding my warranty or screwing anything up since I have a new car. I simply used ring terminals for my big 3. In the future when I have some cash I'll get custom made battery terminals to fit my factory wiring and everything else.
The problem is, they cant even reach to the new terminals. They're not long enough.
Are the new terminals in a different place than the old ones? o.0
No, they're in the same spot, but if you look at the picture, its crimped on to this L shaped, whatever you call it, and then that gets bolted on the old terminal. The new terminals doesnt have any of that bolt on, etc. It's just direct wire in and use an allen wrench to tighten it.
They all go to something, I would trace the wires then upgrade them all.
So that would answer my question? They are needed? I would have to figure out a way to attach those cables to the new terminals...problem is, they can't reach my new terminals...I'm going to need to make a contraption and add on new wire?
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
3K
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
8
Alimoose
Alimoose
Tampa, FL
Alimoose
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
