Blow through, or drop out the floor?
Only The Best
texas
Hey guys! Zach here, I wanted to get some opinions on some design ideas. I made a business when i was 18 building boxes and all kinds of fun fiber/plexiglass enclosures on boats/cars/homes for a couple of years and want to put my experience to back to work now that I am out 1 year out of college. I have a 2013 dodge ram 1500 sport (60,000 miles) and if anyone knows anything about the dodge is that under the backseat is a death pit for headaches with building a box. I plan to do one of two options due to this issue with the truck:
1. I am going to go under the seats and cut out the undercarriage of the truck to drop down a couple extra inches, and weld back a nice square insert to put a much larger box into the truck allowing the space for larger magnets and more airspace.
2. Depending on how much of a pain that will be, I will then decide to just do an average blowthrough. Designs for the blowthrough will be restricted to only the first 2/5 of the bed due to my need of other random stuff. I would also like to build this in such a way that I would be able to remove it should I need to use the entire bed of my truck.
My question is simply, has anyone seen any attempts at dropping out the floor to allow for a large box and high powered system that is firing up under the rear seats. That and how it could compare to doing a blowthrough setup firing forward. Budget for subs/amps/batteries/materials is somewhere between 1500-2500, flexible +1000 (maybe? -options). Thank yall in advance for any input you have to offer.
Is a cap an option? Id do a blow thru by removing the back window and using that as your entry point. Should be good for a couple 15's in a 4th without destroying the vehicle.
Do a blow through it's surprisingly easy and gives you virtually unlimited room. I was pondering different options in my truck like making box that replaces the seats. In the end a blow through was worth it. It gets loud but is also discrete
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
I mixed a trap beat and that christmas song 'silent night' together, then screwed it, bass boosted it, and added a non-stop 25hz note, then put in...
57
5K
been like 20 years since i did just that. 2 l7 15s, 1000watt soundstream usa made amp, 12cu tuned at 34, iirc, that 2 separate vented to the...
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
Only The Best
Only The Best
texas
DirtyDuzit
    May 18, 2024
    May 18, 2024
