SOLD Blown American Bass VFL400.1
sikcavy
1. Product:
American Bass vfl400.1
2. Specs:
I OHM STABLE D CLASS MONO BLOCK AMPLIFIER
LOW LEVEL INPUT AND OUTPUT
FREQUENCY RESPONSE: 20Hz~350Hz
INPUT LEVEL: 0.2V~6V
VARIABLE SUBSONIC: 10Hz~50Hz AT 24dB/OCT
VARIABLE LOW PASS FILTER: 35Hz~250Hz AT 24dB/OCT
VARIABLE BASS BOOST: 0~9dB AT 45Hz
REMOTE GAIN CONTROLLER
TWO AMPLIFIERS LINKABLE CONNECTOR AND SELECTOR
FUSE RATING-350 AMPS, LINKED FUSE RATE, 700 AMPS, USES
EXTERNAL FUSES
EXTERNAL FUSES AND FUSE BLOCKS ARE NOT USED
4600 Watts
3. Description/Condition:
Amp is blown i had it mounted on the floor in my car and the day came that I had a buyer lined up and I was almost home and it went click. I turned it off and turned it on and it made a loud sound like a cap gun so i shut it off and took it out. sat on it for a little while and now looking to sell it. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif Loved this amp.
4. Price: :
400 + shipping
6. Pictures:
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
918
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
sikcavy
sikcavy
Winslow, ME
ppurpledrank
    May 12, 2024
Brendon Jenness
    May 11, 2024
