prisonernumber6 10+ year member
1. Product:
15" AA Avalanche
2. Specs:
Avalanche 15"
● XBL2 TM enabled motor for ultra low distortion
● Single 1 inch thick magnet nearly 9 inches in diameter
● Machined top plate and black plate/pole piece (t-yoke)
● Cast 12-spoke aluminum frame with vents for voice coil
● Beefy 3 inch diameter, 4-layer copper voice coil
● Flat profile ultra rigid epoxy treated paper-pulp cone
● Custom-tooled inverted carbon fiber dust cap
● 27 mm of linear one-way xmax
● 8" diameter progressive spider
● Improved suspension design for high efficiency
● Designed and built in the U.S.A.
Fs 15.7 Hz
Qms 3.5
Qes .334
Qts .305
Vas 300.6 L
Re 3.2 ohms
Znom* 4 ohms (dual 2 ohm voice coils)
Xmax 27 mm
Sd 749 cm2
Mms 269 g
Vd 4.04 L
Pnom 800 watts
Le 2.4 mH
Cutout 14.125"
Diameter 15.5"
Depth 7.875"
Weight 37 pounds
Enclosure alignment Q .577 Q .707 Q .8
Enclosure size 4.0 ft3 2.2 ft3 1.5 ft3
Power handling 500 watts 800+ watts 800+ watts
3. Description/Condition:
If you haven't heard of the ava, they have often been compared to XXX and the Brahma sub lines. In fact, the motor design was licensed from Adire to build this sub. It is a top of the line SQ sub that loves the low end. Search your favorite sub forum, read up, and you won't have to take my word for it.
I bought this sub four or five years ago. It is BNIB, and has never seen power. There is adhesive visible at the edge of the dust cap as well as a fleck on the dust cap itself (~10 o'clock in the image). I received it directly from Chad at AA in this condition. It was purchased as new and I paid full price for it ($225 + shipping at the time). The fleck on the cap looks like it would come off easily, but I have not tried to remove it. See images below.
4. Price:
$225 + shipping. Free pickup in Phoenix! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The ONLY trades I would consider would be for a CD7100 or CD7200mkii that is in like new condition.
Some of you may notice that the price has gone up and the quantity has gone down since I posted this sub about a month ago. Since then, I have decided to keep the other sub for myself, and I also moved half way across the country. My goal was to not have to move it and to get enough money to finance my new build. The move is behind me and I have already purchased my next system (graduation FTW). I am more than happy to sit on this puppy until it sells or I decide to build a HT sub with it.
This may be the last virgin avalanche you will ever see for sale!
ebay feedback:
eBay Feedback Profile for prisonernumbersix
Have sold here recently and also on CACO.com
5. Pictures:
15" AA Avalanche
2. Specs:
Avalanche 15"
Fs 15.7 Hz
Qms 3.5
Qes .334
Qts .305
Vas 300.6 L
Re 3.2 ohms
Xmax 27 mm
Sd 749 cm2
Mms 269 g
Vd 4.04 L
Pnom 800 watts
Le 2.4 mH
Cutout 14.125"
Diameter 15.5"
Depth 7.875"
Weight 37 pounds
4. Price:
ebay feedback:
5. Pictures:
