BNIB MTX TA92001, and BNIB MTX TA5302
JRCF71
Birthsheet shows the 92001 amp tested at over 3500 rms.
Thunder Super Amplifier
Prizm EFX: Selectable Lighting Color, or Pusate to Beat
Xtant Technologies Cooling: Thermal-Regulated, Turbo-Charged Intercooler
RMS Minimum Power Rating:
1000 Watts x 1 Channel @ 4 Ohms
2000 Watts x 1 Channel @ 2 Ohms
3000 Watts x 1 Channel @ 1 Ohm
Wired EBC Remote Subwoofer Bass Level Control Included
CEA-2006 Compliant
Strappable with Another TA92001
Power and Protection LEDs
Parametric Bass Control:
-12 - +12 dB Bass Control
Variable Bass Control Frequency: 30 - 80 Hz
Variable Bass Control Q: 0.5 - 4.0
Onboard Crossover: LP (40 - 200 Hz), Sub (20 - 50 Hz)
Phase Control: 0° / 180°
Semi Unregulated MOSFET Power Supply
High or Low-level Input
Adjustable Input Sensitivity: 100mV - 1V / 1V - 10V
0 Gauge Power Connectors with Built-In 4 Gauge Capacitor Terminals
Wired Bass Remote Control Included
Frequency Response: 20 Hz - 200 Hz
Dimensions: 24-11/16" L x 9-5/8" W x 2-1/2" H
Birthsheet shows the 5302 does 109 rms per channel at 4 ohms, 200 rms at 2ohms, and 400 rms bridged.
View attachment 26550496View attachment 26550495View attachment 26550498View attachment 26550497
Thunder Series 2-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 75 watts x 2 chan.
2 ohms: 150 watts x 2 chan.
Bridged, 4 ohms: 300 watts x 1 chan.
Max power output: 300 watts x 2 chan.
Wired remote bass level input (remote sold separately)
LED power and protection indicators
Tuned Bass EQ (0-12 dB bass boost at 30-80 Hz)
2/1 channel operation
Speaker-level inputs with signal sensing for automatic turn-on
Overload and thermal protection circuitry
With the new MTX Prizm EFX™, you can control the color of the display to personalize your Thunder TA amplifier and tantalize your sense of sight. And if that’s not enough, you can switch Prizm EFX™ lighting to “pulsate” with the beat of the music to heighten the experience even more.
Continuously variable fan speed cooling
RCA level inputs
StreetWires Connectors Terminals
Variable high-pass filter (40-350 Hz, 24 dB/octave)
Variable low-pass filter (40-350 Hz, 12 dB/octave)
Frequency response: 20-20000 Hz
Dimensions: 16-11/16" L x 9-5/8" W x 2-1/2"H
4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together
850 shipped.
JRCF71
JRCF71
Victorville, CA
JRCF71
audiobaun
    May 19, 2024
    May 19, 2024
