Bridging a head unit that is 50Wx4 so that it gives full power to only 2 speakers
  • 4
lurice0
The Only speakers running off my Head Unit are my woofers in my rear backseat, and i want to give them more power by wiring them to my HU differently.
I was thinking about how i can bridge a 4 channel amp to just two speakers by connecting the negative speaker wire to a negative of one channel, and the positive speaker wire to the positive of the other channel. So since my HU is 50Wx4, i can do the same with the designated wires it has on the HU? Like in the picture but using HU as amp.
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
974
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
6
115
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
529
lurice0
lurice0
Keyser, WV
lurice0
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
