Budget Sub and Amp For FRS
I think 1 would be more then enough for me :p
Sweet, gonna add that amp to the cart. Hopefully someplace would have those items on sale especially the HDS208.
208s will be 89 dollars on black friday through cybermonday.
I'd actually suggest you hold off all your shopping till then.
I can vouch for the PPI 1000.1 Phantom amp myself..Ive ran one recently on a SQubed HDS 310 DVC 4 in a 1.8@34 htz and she sounds very nice.Also for kicks ..ran a DVC2 Ohm American bass XFL 12 in 1.6@35 htz on the amp and slammed very well.Id run a ten in that car, if it were me..I think you would be very pleased of running a S.Qubed HDS 310 DVC 2 ohm on that PPI 1000.1 Phantom amp in 1.4-up to 2.0 cu ft from 32-36 htz depending on the enclosure.A ten would be perfect in that car.My niece Has a Scion TC and I placed the American Bass 26801.d,on one AB XFL 10 DVC4 in a 1.6@34 htz and she slamms very nicely.Hits some nice lows and sounds pretty amazing.
Getting ready for the black friday deal here. Is the HDS208 a DVC or single? Couldn't find any info on their site and I'm sure the HDS310 is a DVC. If I run the PPI1000.1, I shouldn't have any issues running the HDS310 either correct?
Also, is it better to get the D2 or D4?
Thanks!
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Higher preamp voltage is to reduce noise, but you generally don't get noise on the subwoofer channel.
4
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
Looking for a pair of budget 8" subs to fill in the low end. They'll be going in a ~1cuft sealed enclosure (.5cuft/sub) under the rear seat of a...
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
917
xFury
xFury
LV, NV
xFury
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
