Can a bad ground cause SQ and Volume issues?
KAC1023
I'm having a issue here, VERY frustrating. I'd redoing my stereo and chasing something here.
Used Alpine 9887
New US Amps MD43 4 channel amp
New RE XXX Components
4 gauge power wire
new RCA's
back half of truck dynamatted
Ohio Generator 250amp Alt (not installed)
4 gauge power
2/0 ground
amp is grounded to the backseat bolt of my Xtended cab F350.
When I turn the volume up it sounds good then sounds like crap when you think it should start rocking, distorts and gets "poopy". I hooked my iPhone up VIA RCA's to see if the used head unit was acting up. messed with crossovers, settings everything, once it gets good it'll start getting crappier. I'm just upset cause I'm selling my old Memphis stuff (check my posts) to go all RE XXX and US Amps setup and I'm not happy. Could a bad amp ground cause this issue? I got some 1/0 black coming this week, gonna run a nice solid ground to the frame, grind that frame silver.
Could be very possible.
When you turn it up the amps are pulling more current. If you have a crappy ground then the amp won't be able to pull the current it needs, most likely sending the amp into clipping and generally just making things sound like ass.
I had a similar problem back when I was a n00b. I had a really shitty ground for my hifonics bx1500d. At low volumes it would be fine, but when I turned it up it would go into protect. Turns out it was a poor ground. Moved it to a nice, clean, thick piece of metal and never had a problem.
yea, I am being a n00b here. I THINK that is it, but the weather has been to crappy to get under there and mess with it. Just wanted to get a second opinion, thanks btw, like your pic, LOVE Caddyshack, "how would you like to mow my lawn?" I just wanna hear all the hype about these XXX components, can't wait to hear them smash my ear drums.....
ok, ran a nice new 1/0 from the distro block through the floor to the frame. I cleaned the frame up real nice, undercoating was a pain, used a 5 grade bolt, though the terminal, through a star washer, through frame to a nut, tightened the hell out of it..... and it still distorts, wtf!! I mean the speakers are in the back extended cab doors and the tweeters are up high. I want volume and this isn't quite doing it for me...
ok, more follow up, got my hands on a Osilly and I am impressed with my 9887, full volume, no clipping, turn the amp up til it clipped, just before and the speakers sound good, but I just though they'd be louder. They are behind me on my extra cab doors, maybe once I put the other set up front it will all sound nice.
I used a older Pandisc CD, I used that Steve Meade way. played a 1Khz tone and set it up that way, I should of used a -10db? and set it for a smooth curve? crap, no biggie, easy to get too..
What about if the amp has good ground and voltage but not getting out put from the radio?
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
9
That's why I said it really depends on the sub 😂
16
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
KAC1023
KAC1023
Greenwich, CT
1aespinoza
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
