can i put an electronic crossover to my amp that already has a bulit in one?
  • 3
jlman
Review Committee
Ok i have a rockford 120.2 and it already has a bulit in x over i just bought a electronic one that i am planning to put in is thier any need for it i herard the x over on the rf amps **** would this work?
I have a punch 360.2 and a punch 400.4. I installed an external electronic crossover and it made a big difference. An external crossover is much more efficiant than the crossover filters within an amp.
Yep it will work. As previously stated it might make a difference. The problem with most built in crossovers is the slopes just aren't that great. Most are 12db an octave.
Ok i just put it in today it is a radio shack electronic xover system( i know it ***** but its only for a little bit) well anyway i hooked it up andit sounds like ass.The subs are really rumblie and distorty it sounded 10 times better before so i dunno what the problem is.I did splice into the power wire going to the amp and use that power and the same for the rem so is that wrong i used a differnt ground though well if you guys know please anwser back it does have the same 12db octave output same as my amp so should i toss it will it even do any good?
jlman--disconect the radio shack crossover
and just use the crossover thats built into the amp
try looking for audiocontrol 24xs electronic crossover
or any brand--precision power,rockfordfosgate,kicker
zapco,xtant, that has better quality parts built in.
try looking for one with 24db slopes:cool:
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
609
I think he wants to use the existing enclosure he has, and its cut out for a single Ten inch sub at the moment
19
3K
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it. An...
6
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
jlman
Review Committee
jlman
kirksville
billetz23
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
