Car amplifier makes loud static beep/pop when i turn the ignition on/off
  • 2
christbi2
Oslo
I just installed a new 4channel amp in my car for my speakers. I also have a mono amp for my sub. The mono amp is connected to the 4 channel amplifier, but whenever I have the mono amp connected It makes a loud static beep/pop when I turn on/off the ignition. When I disconnect the subwoofer I get no beep/pop , but then I cant use the sub. I have grounded both amps and I use a splitter for my powercable to the amps. The signal wire runs directly from my 4 channel amp to my mono amp.
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
If you want something weather resistant, get a marine amplifier.
Check for a blown fuse (or fuses). Referring to the car and not the amp. How do you have the amp wired? Power is directly to battery and ground is...
christbi2
christbi2
Oslo
christbi2
audiobaun
    May 19, 2024
    May 19, 2024
