Car Audio Terms defined
thanks for all the definitions, not that anyone cares but I copied and pasted that to word and it's 50 pages :thumbsupw //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
as far as bandwidth goes ..... it pulls about as much as a regular post, not even close to an image size .... roughly 1/5th the size of a single regular image depending on varying factors
Great list. You forgot Crossover slope:
The crossover slope describes how sharply or quickly the crossover attenuates (decreases) the amplitude (strength) of audio signals at frequencies above (low pass crossovers) or below (high pass crossovers) the crossover frequency. The slope is described in dB per octave. The higher the value, the sharper the roll-off, and the more control the listener will have over which frequencies are played by any particular speaker. A 24dB/octave slope is considered very steep (good) and a 6dB/octave slope is relative low (more difficult to control audio signals).
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
322
16
771
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
487
KARLEON
Livin' Legend
KARLEON
Chattanooga, TN
JohnC005
Brendon Jenness
    May 8, 2024
    May 8, 2024
