Car With Trunk Pass Through
  • 2
Hulk311
LA
I'm looking to buy a new luxury car that comes in two trims. The standard trim has a trunk pass through (the middle seat folds down so you can fit skis, etc. through it to the trunk) while the VIP trim does not have the trunk pass through. I plan on installing an aftermarket sound system in it.
How does having the subwoofer in the trunk with no trunk pass through affect the way the subwoofer sounds? The car has a lot of sound deadning in it already (stock) so I think it would block most of the subwoofer sound.
The first car I put a sound system in was a '98 Taurus, I just removed the two speakers from the rear deck so the sound from the subwoofer in the trunk could get into the cabin.
ANY car with subs in the trunk will have significantly less bass with the seats up than when their down. With a hole in the skii pass. It allows some bass to come through. Will it change the sound of it? No, Will it change the intensity, yes.
How big is the skii hole? Big enough to put an 8 into? There is a few different options you can do. something like this works too.
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Now coming out to the wholesale distributor, Sub sonic car audio new brand owned by selelectronics since 2000. Look for new subs ,amp, empty...
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
573
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
975
Hulk311
Hulk311
LA
The Camry
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
