Cardboard cut outs for speakers?
  • 3
ekah
hawaii
Could I use some cut out cardboard circles for my speakers I found? It's pretty thick and wanted to use it to be a spacer between the front of the speaker to door panel so like a funnel to the panel not to be mistaken from the back of the speaker to the panel bit the front of the cone to transfer waves and thinking of using balistic mat to cover the cardboard and maybe sticky it on the cone of the speaker or maybe glue? Or is this a horrible idea?
Yup it is. Because if moisture ever gets to the cardboard, before you know it it will start stinking and grow mold, etc. It'll be weak in the longrun.
Better idea is grab some 1/4" wood, not mdf but rather something like plywood, or some other type of board. It's fairly enexpensive and most hardware/lumber places usually have small cut sheets for cheap.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
233
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
9
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard...
ekah
ekah
hawaii
ekah
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
