Changed port for SA15, what did I do???
All around the sub air was coming out. The frame of the sub was against the wood causing a large gap. With my ear I can here it all the way around the sub. Glad it was an easy fix.
Same here.
You my friend need the Jasper jig.
Using the jigsaw to cut the mounting cut is so 80's lol.
I get it your shoulder is in bad shape but that jasper jig certainly helps a ton. Wish it existed a number of years ago.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
697
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
870
843
One_crazy_dude
One_crazy_dude
Jersey Shore
Boomin_tahoe
    May 16, 2024
    May 16, 2024
