Check my amp?
  • 5
I put the SSL EV3000D amp on my test bench .... it only makes around 600 watts RMS ... for real dude ....
Just no .....
spend $40 more$$ and get an AB or MA or something that actually makes a bit of power ....
Okay. I'd heard soundstream was a good brand though which must be true because I read it on the internet! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Glad to have such a helpful community here, what about this amp? Amazon.com: Soundstream TA1.2000D Tarantula 2000 Watts RMS Mono Amplifier with Bass Knob: Automotive
Or if anybody has a recommendation on a good amp that is sub $300 range that can put out around 2000rms @ 2 ohm and anywhere from 700-1500rms @ 4 ohm please shoot my way!
Okay. I'd heard soundstream was a good brand though which must be true because I read it on the internet! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifGlad to have such a helpful community here, what about this amp? Amazon.com: Soundstream TA1.2000D Tarantula 2000 Watts RMS Mono Amplifier with Bass Knob: Automotive
You don't get something for nothing. Soundstream is junk and soundstorm is even worse. Realistically if you can't afford a proper amp you certainly can't afford the electrical upgrades to actually power a big amp so you should be shopping with something that is honestly rated 1000-1200W. Companies that have to lie about what their product can do are shady. You will have poor performance, dubious reliability and little to no re-sale value down the road.
I like how everyone's honest about how ****** these things are yet there's a guy with a sound stream 3000 for sale and guys are actually trying to barter with him
The tarantula amps are decent and can do near the power it advertises.
For the money you want to spend you should try getting a sub(s) that can be wired at 1 ohm.
I say this because the higher power needed on higher ohm scales get expensive since the resistance makes the need for more expensive hardware.
Anyway as for 2 ohm at 2000 watts you will be in the 500+$ range either brazillian amps or soundqubed amps or even a hifonics if your desperate.
For 300$ i would go with an american bass 150.1, but thats at 1 ohm in high power reference.
Sent from my draconis using Tapatalk
These are decent budget subs. The box design isn’t bad at 5 cubes for these, but I’d drop it down just a little and raise port tuning up to 32...
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
9
HI all - I don't have a windows machine and thus can't use WINISD, so I've been playing with speakerboxlite.com Can someone cross-reference this...
shuhroo
shuhroo
Women, Mm
los33
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
