Chrysler 300 Big 3 Help Please. *pics attached*
  • 2
znewberry
Illinois
2013 Chrysler 300
I understand running the big 3 isnt of much help on these cars. however I have enough 0 gauge and would like to do it. I havent found any good videos or guides for this car probally because its not much needed.
[Question 1]
The factory power splits into 2 on both ends. In the trunk it goes to a fuse box and also travels to the alternator and another fuse box / positive post. Do I run the 0 gauge to the fuse box/positive post and alternator? or just from battery positive to alternator and ignore the fuse boxes? Also can I just attach my new 0 gauge to the wing nut on the termials I have leaving the current setup intact aswell?
https://ibb.co/iNhV46
https://ibb.co/fXtgBm
[Question 2]
What is this wire to the right that loops up? the one that goes south is battery power to alternator. is the second one a ground of some sort?
https://ibb.co/gS3sHR
Big 3 consists of the following:
1) Alt Charging post to battery +
2) Engine to Chassis (this helps alt ground)
3) Chassis to Battery -
Thats it. Leave your factory wiring, just add Big 3 wiring too it
Edit: here a vid that might help
Personally, I solder all my terminals over a crimp
Thank you, Can I attach the 0 gauge to where I have my red arrow pointed?
https://ibb.co/ncDgBm
Thank you, Can I attach the 0 gauge to where I have my red arrow pointed?https://ibb.co/ncDgBm
yup. Do both terminals tho. You can get away with factory terminals if you have a single run of 0 g running to the amp. Otherwise, it gets crowded quick.
Edit: That looks like a Hefty factory ground. what gauge wire is that?
i can see how it would get crowded quick. I see upgrading battery post in the near future with more batterys ect.
much appreciated!
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
6
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
znewberry
znewberry
Illinois
znewberry
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
