Classic Car Stereo Issues
  • 4
eseel
I am looking to put a new system into a 76 corvette. I want the system to be a shaft style unit so I am not cutting into the dash. There are companies like Custom Autosound that make systems to fit but from the forums I am hearing they are poorly built units so you are paying a lot for nothing. What I would like to know is if I am going to be running an external amp, does the quality of the head unit matter?
I have two choices; 1- buy a vintage (80's) shaft style unit from a well known company like Alpine and add an amp to help with the sound quality. With this choice I am limited to the number of current day technologies I can add such as MP3/ SD/ USB/ bluetooth etc.
The second choice is to buy a current day unit from a company like Pyle (https://www.pyleusa.com/am-fm-mpx-mp3-playback-w-usb-sd-aux-in-a-pair-of-4-speakers.html). These are extremely cheap receivers but have all the current bells and whistles.
Question - If I buy the cheap Pyle receiver can I make up for the poor quality receiver with quality amps and speakers?
Any help is much appreciated.
Just google classic car radio replacement and you'll get a handful of companies. The one and only benefit of going this route is that the radio will look stock or old fashioned. If you want to run aftermarket amps and a big system then just get a mainstream brand because they come with all the plug ins and hookups needed. We went with a Kenwood in our Viper powered Desoto because we wanted to use a 5ch amp and have usb, aux and bluetooth capabilities.
Ok thanks, i suspect that this one i uave may be faulty. I will purchase another one for the sake of it and see, thanks
5
633
Well, generally speaking, I would agree. But that is like saying that PRV, Stetsom and Taramps are all the same. Similar maybe, but not the same...
8
It is an L port. You might as well add three 45's. Add one by the leg of the L and the two that I showed you in my other post.
6
Thank you both :) I'll probably wait it out for the SA-12 v.2s in that case. Always learning on this forum and I appreciate it so much as always!
6
It was also 1960 and the quality of sound you could get out of the loudspeakers of the day was going to be rather anemic even given optimum...
12
eseel
eseel
Hockessin, DE
THATpurpleKUSH
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
