Control box/bass knob
SlugButter
CarAudio.com VIP
4,664
2,146
arizona
work is a little slow this week so I decided to try building a bass knob/volt meter/switch box for LEDs and a future motorized amp rack. Im a cheap SOB, so I’m using an old black and decker power inverter housing that I ripped apart, cut up and painted. I cut the housing and left it a little large to add more switches and knobs into it later. Anyway, not much of a build log, but it’s a fun little project for the day.
The knob is imported all the way from Mexico. Cholula is kind enough to stock these at your local grocery store with free hot sauce attached to it.
Everything works as it should. Much better potentiometer than the bass knob that comes with the amplifier. Smooth volume increase on the whole sweep. Need to get longer RCA cables and install it up front.
Far far better control of the bass with this potentiometer over the bass knob that came with the amp. The stock bass knob only really worked on about half the sweep. im Going to add a potentiometer to control the speed of my cooling fans and a switch to control the LEDs for the amp board. Maybe a dimmer switch. It kind of turned out better than I had thought it would. I dont like the cheap looking volt meter, so I might change that out.
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
This is in a 2015 F150 regular stereo and I'm using the front speakers for a signal. The EQX is hooked up speaker level. I put a cheezy line...
I assume the plugs are if you have factory equipment like a amp, etc.
936
Thank you for your reply, your solution is great, however I'm really wondering why there is no dedicated button or even a quick access on the...
885
SlugButter
CarAudio.com VIP
SlugButter
arizona
SlugButter
    May 10, 2024
3toneEYZ
    May 10, 2024
