Correct Wiring Harness?
Masikr
29
Bay Area
I plan on installing a Kenwood ddx372bt into my 91 Lexus ES250 and am wondering if this harness (Metra 70-1761) will work for this application. Also, is it true that since this HU is an upgraded system that uses much more inputs than the stock stereo I'll have to get an RF modulator to use accessories like an aux input for ipods and what not?
Go on over to crutchfield, put in year, make, and model of your car, even if you don't purchase from them, you can find out what you are in need of for your install dude. That is where I do all of my research, very helpful, good luck dude.
Yes I've done that and sadly they say they have not "fully" (or at all) researched my car.. It's ok, thanks for the input tho man, I've kind've figured this thing will be a plug and play type thing lol, figured I might as well try.
Try checking the Camry equivalent dude, that may help.
It does say it'll fit a 2nd gen Camry, which is "basically" what I have. My car does have some old *** Pioneer stereo system that I don't know came with the Camry or not, but ya the harness work based on that. Sadly it's saying it'll only fit 5 1/4" speakers in the rear deck which is smaller than what I have to throw back there lol.. Every time I would go to the audio shop they would give me a different response as what size speakers it needed... Last time I went in the guy searched the code on the rear speakers and could not find anything on them. It's ok i should've just opened it up back there and figured that out myself beforehand I guess. Thanks though dude.
Your welcome dude.
Depending on your upgrade, you may be able to bypass the rear deck dude. Some here do either kick panels or mids in the doors and tweets in the a pillar. That is the way that I have mine, front door mids and a pillar tweets.
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
763
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
393
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
461
Masikr
Masikr
Bay Area
bigaudiofanatic
    May 31, 2024
    May 24, 2024
