Couple of short ported questions
  • 1
marcopolo
I'll be brief:
1. Is it smart to tune the ported box below the Fs of the sub? Is that even possible, is it good or bad? My sub is Fs=32 and I was wondering what would the outcome be if I tuned the box to 30Hz?
2. Is it O.K. if the box has two slated sides (the front - where the sub is, and the rear - where the rear of the sub is facing)? It's like 55 degrees angle on front side and like 75 degrees on the back side - like a: ------------
/--) sub \
Not a SVGA, just to make sure you'll understand.
Oh and 3. (not a couple anymore ;-) : How thick (max) should the be the lining on the sides, so it wouldn't "change" the volume so much it would change the tuning frequency?
The box is 65L (2.3 cubic feet in your dimensions, i think) and I plan to put some pyramid foam on the three opposite sides.
Thanx!
I saw that my classical art picture didn't came out as well as i expected, but I hope you get the idea from the text. It's like a triangle without a peak at a top but a flat side that is shorter (a half of the bottom side) that the bottom. Sorry!!!
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
6
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
7K
Yea. I literally spent 2 hours perusing the site. Got to love a helpful website. I bet that they have thought of everything that could possibly...
7
952
So is the radio harness spliced direct to the OEM harness? There is no adapter harness?
12
marcopolo
marcopolo
Slovenia, Central Europe
marcopolo
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
