Crescendo vs Soundqubed
Whats up fellaswhat amps would you recommend for 2 fi q 12, 1500 rms going sealed!
I have bn searching for 2 good quality, efficient, inexpensive amps, still not sure what to get.
So far i've narrowed my choices down to symphony 1500, ct sounds 1400, saz 1500, sax 1200, rf t1000-1bdcp, rf t1500 1bdcp (I noticed they have several to choose from), arc xdi 1100.1
Is any of these amps ideal? Or are there others I should tk a closer look at?
Start a fresh thread bud
Of those, I personally would prefer the Sundown or RF.
@ denim
Would you recommend which models for both sundown and rf i should go with?
Im not to knowledgeable as to what will be too little or too much power
thanks again
@ denimWould you recommend which models for both sundown and rf i should go with?
thanks again
If you can budget for and can fit the larger model, go that direction. Headroom is a nice thing to have. Too much power is only an issue if improper gain setting occurs, or the wrong box for the power relative to the subwoofer etc. Meaning it is usually nicer to have the stronger amp not work as hard to have the same output as the smaller amplifier that is being pushed harder to reach the same result.
ATOMICxTomato
ATOMICxTomato
Dallas, Tx
denim
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
