Crossfire vr1000D fuse
  • 4
i have 1 Crossfire vr1000D and its "missing" one thing, where is the fuse?
well one thing i can tell its not outside an its not inside...
its the first time i see a amp with no fuse on it....
what happen if something goes wrong? there no amp fuse just the cabe fuse im afraid thats not enough to protect the amp or is it?
if it don't have a place for a fuse just buy a in line fuse some peeps use fuse based on wire size some get them based on power the amp has in your 1k amp case 80-100amp fuse should be fine something like this https://www.ebay.com/itm/Earthquake-Sound-FBNL-1-0-1-4-Gauge-ANL-In-Line-Fuse-Holder-with-100-Amp-Fuse/151716634124?hash=item2353041e0c:g:k-EAAOSwH-dZ6oIK
i have a 80 amps in line fuse near the batery, but its the first time i see a amp without fuse :p
but i will upgrade it too, maybe 1 120 A fuse at the batery and a new spliter at the amps and 1 fuse for every amp (probably 60 or 80 A for speakers amp and 80 A for sub amp)
That amp has no on board fusing, when that happens fuse for the size of the power cable. That amp will draw at least 100a.
humm so its bether to go 120a at the batery, spliter at the back near the amps and 100a to bass amp and use the 80a that i allready have for the speaker amp
Some amps have built-in fuses/fusing.....a lot of your 4 ch amps will/might, as well as mono amps, but some of the most biggest amps, such as Soundqubed 7k won't have it because there's no room to put 50 fuses on/in the amp and it's easier to have one in-line. A lot of mfgr's will suggest fusing for their amps on the website.
  • Locked
Looking to buy a Crossfire CX2L. Anyone selling one? Serious buyer.
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
498
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
644
Portugal (europe)
Boomin_tahoe
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
