Cutting speaker holes in door panels?
if you can get a whole saw big enough that is the best way but if you dont care how it looks and have another tool that can do the job already then use it, it will be much cheaper. as long as you do an ok job the speaker will cover the hole up enough that it will not show.
i found a 5.5 inch hole saw, is this good for a 6.5 speaker? i just need it to fit where it shows like this
if he plans on mounting the speaker in the hole a 6.5" driver doesn't require a 6.5" hole. It's usually around 5.75"-6".
You can use a dremel and get a pretty neat hole. Cut you a template circle the diameter you want your opening out of some scrap wood. Use a rotozip bit in the dremel. roto zip bits have a round tip with no flutes. Set your depth on the dremel so the bit goes through the plastic with only the non fluted tip protruding through to the other side. Now use the circle you cut as a guide and position it where you want your hole. Then just use the dremel and follow the pattern like a flush trim bit. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What's shown in the pic is probably fiberglass work and not just done by simply cutting a hole in the door panel. Yikes.
if you can find a hole saw, thats gonna be the best method. since the speaker is gonna cover the imperfections though, a dremel should be more than sufficient
OHHHHHHHHHHHHHHH in that case , screw a hole saw. Just use a jig saw or a dremel. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
x2.
I hope that the pod isn't only going to be attached to just the flimsy door panel.
Yes this thread is old as eff, but I have 2000 Acura to and I have to cut bigger holes in the metal door. Current holes are 4.4 and I need 5.7. What’s the easiest way to cut a clean hole.
Jigsaw:
5.75 hole saw
I feel like the 5.75 hole saw blade is a bad buy because I’m not an installer and won’t regularly have use for 5.75 hole
updated thoughts?
You're probably right. I have two Taramps smart 3 amps and four 10 inch CT sounds tropo for bass. I'm actually going to only install one of the...
14
For me.. a compact amp that wouldnt take up a whole lot of room and not real expensive for a 350-600 rms sub@2ohms or even 1 ohm load id look at...
19
Restarting the phone every 1-2 days is a plus too. My moms phone is useless by the third day of not restarting. As soon as it's restarted it's fine.
11
gain set well below "Normal" and base boost is off completely
15
marvinwillis
marvinwillis
Hinesville GA
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
