Dayton Ref Sheilding Removal
Is there an audible differene with keeping the magnet on or off?
sure isn't //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif -- the motor structure isolates the coil from the bucking magnet nicely -- making as if the bucking magnet doesn't exist...
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif
The bucking magnet is only there for video shielding. No audible difference with or without it.
And, as mentioned and linked......basically just smack it with a hammer. Don't hit 'er extremely hard though. Just enough to loosen it up.
This is awsome... I know have the depth to put these either in my kicks that are under construction or my doors.
THe kicks are less then 1 ft. center to center from my stock door pods. The daytons will be running from around 40 hz all the way up to around 1.5k. Should I put the daytons or my midrange cdt's in the kicks. The kicks are not angled towards the driver they are merely off axis like the door pod. THanks for the replys.
Well I need new speakers. I followed the directions listed above but for some reason mine separated at eh ebacking plate not the shield. So when I took off the shield it took half of the speaker with it.
I hit it in all the right places and now I am out $80. I'm sort of pissed.
Its cool. I just hooked up my cdt's and did my best to cover the scars from my kick panel augmentation. I haven't run 300 watts rms to the cdt's for a while and I forgot how good it sounds. Maybe I'll try to just leave it for a while.
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
Ive been looking at amarican bass xd 1222 or 1244 ,and sundowns e series, they both seem very good , can't verify sound quality tho but I know...
37
9K
Berry47
Berry47
My Pants
Berry47
    May 12, 2024
Brendon Jenness
    May 11, 2024
