DD rebuild or Sundown
Hey, Cannot find any input anywhere else. I'm at a loss of decision here. Should I have my DD1510 Rebuilt for $130 (no bass for 2 weeks -.-) or Sundown SA10 rev2 for $200.
I have 600w going to the DD1510, which is now bottoming out because I turned my amp gain/boost up in eagerness for more bass, which kicked me in the *** now. no, I cannot upgrade the amp and my 1.3cuft ported box is my max space available in my standard cab Dakota. right now the box and 1510 are hitting mid-high 130db, ****** slammin. but if the sa10 will hit the lows better and pound harder than the 1510 id rather get the sa10. money is no issue, as I can always make more. I only have 6.5' mounting depth so anything with a bigger magnet then the sa10 will not work for me. I appreciate all input and advice, whether your kind about it or a ****. please educate me.
Lot of confusion about digital design (I actually contacted them a few months ago and got a clear answer).
Digital Design has the actual real "made in usa" label (which is very hard to get, almost every single material used in the product has to originate from the USA for you to get a TRUE "made in usa" label).
"Assembled in USA" and "Built in USA" are the marketing gimmicks that give the USA label some flake (neither of which is Digital Design).
"Assembled in USA" usually means almost all of it was it glued here with foreign parts or in some cases literally all of it is foreign
"Built in USA" means some of the parts are of USA origin and some are not (to get the step up from "assembled" to "built" you actually have to show that there was actually construction/workmanship involved). This category (built in usa) is popular in car audio (higher-end sundown products, SSA, Fi, Ascendant fit this mold).
Digital Design explained this fully to me and said the only product they import is the basket. The FTC (who is the commission that regulates the labels) considers it made in USA
Thanks. Nobody ever believes me.
But if you ask Facebook DD, SQ, AB, Massive are all the same
What’s up y’all, new to this place… today actually… Idk, i guess if I’m gunna ask for help wit this mess, now is prob the time…. First things...
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
665
ClutchKicka
ClutchKicka
Philadelphia, PA
LosIsATool
