Did something wrong when installing new stereo 2003 in Mitsubishi Galant ES Infinity
  • 4
Freshesh
So this is a used a car I bought from a private seller almost a year ago. Recently the factory stereo started failing so I decided to install a new one and tried doing it myself. I got the correct harness for the sound system (it has the infinity setup) and put it all together last night.
There were two antenna wires and I couldn't use the smaller wire so I just wrapped it in electrical tape and let it be. There was a long black grounding wire that came attached the new stereo's harness and I attached that underneath a bolt that I think is just attached to the chassis so I'm hoping that's not where the trouble is from. Anyway I had the negative terminal disconnected while I was doing all this.
I reconnect it and everything is working great. The car starts running when I turn the key and the new radio is playing music. Then the lights start to go dim and everything dies.
I go to the battery and find that the negative terminal had become detached while I had the car running. It was a little loose to begin with so I wasn't surprised. I reattach it and try to start the car again but it won't start. Just makes this clicking noise from the area around the ecu and fuses.
Also the headlights are flashing and if I open a door the door ajar light on the instrument panel starts to flash as well as the dome the car. When I turn the key to the on position some of the instrument panel the way nothing happens. When I turn the key to try and start it there is absolutely nothing. No sound, no cranking, no anything.
At this point I'm wondering if I activated the electronics immobilizer? Or some kind of at this point alarm system? I don't think the battery is dead because when I first reconnect the battery the headlights will come on. They seem strong and after I open the door or start messing with it is when they start flashing. I'm bringing it in to a repair shop tomorrow but there are no Mitsubishi dealers anywhere near me so I'm not able to get it into a dealer.
Also I cleaned the negative battery terminal and post and attached a shim post so it's not loose anymore and that didn't change anything.
Sounds like a dead battery.
---------- Post added at 10:34 PM ---------- Previous post was at 10:33 PM ----------
Just noticed your in MI
@Hertz Mafia is in MI as well. He can help ya out.
Do u have a dmm to check battery voltage? My guess is the battery has enough power to turn headlights on but not enough to start the vehicle. Prly just need to charge the battery and good to go.
Dammned that sounds good!! I usually dont eat out. But Hmm. Tempting
91
5K
Ya man. Thats No Good. As Stated. More than likely blew the power supply. I had an amplifier behind a rear truck seat and I forgot about the...
999
Yes, it was designed with the help of Steve at Amp Medics. They are great amps, I have many friends that run them.
Send it means play it. I didn't say send it back. I'm sure it's fine.
43
5K
Thinking I will go 4th order. 3- 1 if i have the room for it. Motors to the front to help them cool faster.... and we are painting the baskets to...
Freshesh
Freshesh
Michigan
Hertz Mafia
    May 12, 2024
Brendon Jenness
    May 11, 2024
