Digital Design C4a
  • 2
9515ROB
TEAM DTF
2,385
Sherman IL
1. Product:
Digital Design
2. Specs:
Series: C
Input Sensitivity: .2V-8V
Variable High Pass Filter2: 20 Hz - 5kHz at 18dB/Oct Izuka
Subsonic Filter: ---
Variable Low Pass Filter: 50 Hz - 5 kHz at 18 dB/Oct Izuka
Clipping Display: LED
Tested Voltage: 14.4V
Tested THD: 1%
Model: C4a
Cont power at 4 ohm: 100W x 4ch
Cont power at 2 ohm: 150W x 4ch
Damping Factor: >250 @ 2 ohm
Cont power at 1 ohm: 175W x 4ch
Cont power at 4 ohm Mono: 300W x 2ch
Cont power at 3 ohm Mono: 350w x 2ch
Dynamic Power: 400W x 2ch
Efficiency thru Output: >65%
Dimensions - mm: 380 L x 235 W x 53.4 H
Dimensions - inches: 14.96 L x 9.25 W x 2.1 H
Signal to Noise: 92 dB
Shipping Weight: 14 lb
3. Description/Condition:
7/10 cosmetically has some scratches nothing to major
10/10 mechanical mechanically
4. Price: :
225 shipped
5. Pictures:
[br][/br]
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
634
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
9515ROB
TEAM DTF
9515ROB
Sherman IL
9515ROB
    May 12, 2024
Brendon Jenness
    May 11, 2024
