Digital designs cs-6.5 priced to sell
  • 2
cal
DD Audio: Components CS 6.5
The tweeter side of the DDCS comp set is our new DDT2, a 25mm, ultra-light diaphragm tweeter. This new diaphragm is less than 0.003 of an inch think; that's almost nothing of a mm. This proprietary fabric is so thin its virtually see through, well, actually it is see through. The ultra-light dome is coupled to a low-distortion, neo motor with flush/surface mounting hardware and metal grill options. The 2-way crossover features low distortion coils and metalized polypropylene caps that pass the source without degradation. The DDCS comps are purposefully built, enthusiast quality comps -- everything you need for great sound and nothing you don't.
Crossover Frequency4kHz - 12 dB/OctCutout Diameter5.65"Frequency Response40Hz - 25kHzMounting Depth (in.)1.93"Power Handling160W per CHSensitivity91 dBShipping Weight11 lbsTweeter Coil Diameter25mmWoofer Diameter
THE SET WAS BOUGHT NEW UPON ARRIVAL THE BOX WAS DAMAGED AND THE TWEETER WERE MISSING THE GRILLS AND THEY ENDED UNDER THE 1 MID .
I JUST REPLACED BOTH TWEETERS AND JUST TESTED THE MID THAT WAS ON TOP OF THE TWEETS TO MAKE SURE IT WORKS. I DID TEST CROSSOVER SO I WOULD NOT DAMAGE THE MID BOTH WORK FINE AND HAVE 10 MINUTES OF PLAY TIME . SO BASICLY THIS SET CONTAINS
2 NEW TWEETERS,1NEW MID,1NEW CROSSOVER AND 1 TESTED MID AND 1 TESTED CROSSOVER .
TAKE A LOOK AT PICS FROM 7841-7844 ARE THE TESTED PEICES .
THIS KIT INCLUDES MOUNTING HARWARE FOR TWEETERS AND TWEETER GRILLS .HOWEVER NO MIDRANGE GRILLS COME WITH THIS SET AND I CONFIRMED WITH DD THEY ARE SOLD SEPERATE .THIS SET DOES NOT HAVE AN OWNERS MANUAL BUT IS PRETTY STRAIGHT FORWARD.
I WILL TAPE THE BOX AND AND PUT EXTRA PACKING TO HELP SO FURTHER DAMAGE DOES NOT OCCUR ALSO I WILL INSURE FOR THE VALUE.
100 SHIPPED PAYPAL ONLY AND NO TRADE PLEASE
FREE CON U.S.
http://www.caraudio.com/forums/itrader.php?u=1006316
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
7
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
cal
cal
cal
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
