Digital designs zse new...
  • 3
cal
DDZSE # 33 OF 50
4 OHM power : 1900X1
2 OHM power :3550 X 1
1 OHM power :6200 X 1
over 7k @ 14.4 and dd underrated
FREQUENCY REPONSE :20 HZ- 250 HZ
SIGNAL TO NOISE :100 DB
LOW PASS CROSSOVER SLOPE :24 DB
LOW PASS CROSSOVER RANGE :35 HZ-250 HZ
SUBSONIC CROSSOVER RANGE :10 HZ-50HZ @ 24 DB/ OCT SLOPE
IMPUT SENSITIVITY :6V-0.2 V
WORKING VOLTAGE :8.5 V-16V
FUSE RATING (EXTERNAL) :600 A
POWER TERMINAL SIZE :2X 0 GUAGE
bnib only opened for pics and to inspect and never been used mounted etc . have another one if somebody needs 2 the other is number 6
includes remote gain, cable, allen keys, inspection card, owners manual and all dd boxes as seen in pics .
last chance to own a new ddzse as only 50 of these were made and i have own 3 and this is the last new one i have
1,450.00 shipped in the u.s.
no trades
How much for the pair and what shape is #6 in?
the other amp is lnib no scratces on the case and only inside the mounting holes is a pin size scrtach cant even tell its been used , the shop demoed the amp and went right back into the box. both amps i can do 2700. unfortunately due to shipping and paypal fees thats the best i can do each amp will be insured for full value
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
7
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
cal
cal
cal
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
