do caps work?
This is relevant and deserves consideration.
.https://m.youtube.com/watch?v=T9mlvbF0flM
Sent from my SM-G960W using Tapatalk
The capacitor is going to act like a small sponge so if you have a very hard Bass drop or some other type of short bursts of full power that capacitor will unload its juice instantly yes somebody can make a joke about that if they want. Anyways it's only goal is to keep unnecessary voltage fluctuation from happening but it does not store power for a very long period of time especially not if you run your system with the car off if it's between that or battery I would go with the extra battery because even though it does not discharge as fast as a capacitor it's a better sponge overall and you can play it with the car off
shouldn't have issues unless your vehicle is a unibody which would require a direct ground run front to back.
You could just drag a bare wire behind your car. If it's touching the ground, that's a direct ground run.
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
I've been very happy with my jy battery, but I likely won't buy another jy product. It irritates me they discontinued their hp40 battery...
ekah
ekah
hawaii
gckless
audiobaun
    May 19, 2024
    May 19, 2024
