Do I need 2 alternators?
sundown20
Im planning on getting 2 sundown sa 15s, audioque 2200w amp to power the subs, all new rockford door speakers, a 750w audioque amp to power the door speakers, and a xs audio 950w battery to power the 2200w and just hook stock battery up to 750w. Do you guys think i would need another alternator to power all of this? Or maybe just a better alternator. And is the 950w battery enough?
AQ750 is a mono amp, won't play full range for components.
You could get by with a G31 sized batt and BIG3, depending upon how long you play it LOUD.
214
Thanks for your input! I did some research and wanted to share what I found for anyone else in a similar situation. It turns out that the Honda...
181
511
sundown20
sundown20
Grosse Ile, MI
lionfamlee
    May 20, 2024
    May 20, 2024
