Do i need 2 batteries or another alternator with this system?
  • 4
!.beat killer.!
I have a soundstream picasso 2 channel AB amp. Its 540 watts total rms but at 4 ohms its 180 watts rms x 2 channel. and at 2 ohms its 270 watts rms x 2 ch. i will be using 4 ohms. The model number for this amp is pcx2.540. The amp is huge in size it is 20 inches. I just want to make sure that i can just use one battery. Also i think i am going to use 2 12" SOUNDSTREAM arachnid subs that have 250 rms and 500 watt peak. I dont know to much about radio stuff but i just want a little system nothing huge. i would appreciate if someone could tell me if my radio system would be ok with one battery or do i have to have 2. thank you!
im running a Pyramid PB1281x(I know. lol) and 2 Diamond D3 10"s and have no problem with a 65amp alternator. you should be fine.
alright so who's the clowns, we got the idea. you can stop now.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
180
I also just checked the voltage and the voltage on the amp in 12.85 and the rest of my stuff like my lc2i and remote out wire is 12.10. could that...
6
71
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
134
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
476
!.beat killer.!
!.beat killer.!
sardis city al
osl
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
