Do I need to upgrade my alternator
mikeysheff12
CarAudio.com Recruit
I’m building a lithium bank soon when the parts come in and I’m not sure as of how to wire it up. I still have the stock battery and stock alternator. I planned on keeping it and putting the lithium bank in my trunk. Do you connect it just like you would a secondary battery? Also do I need to upgrade my alternator. I’ve seen quite a few things on overworking the alternator and blowing it up possibly. I’m not sure if that would be the case with mine. I’m building a 64ah bank to power a 2k rms amp
I upgraded my alternator before I added lithium. If i could do it again, I would add lithium first. I say add lithium and then decide if you need a bigger alternator. Alternators lag demand by enough that your headlights still dim.
Alright. Only one more question. How do I wire it up. Do i wire it straight from my battery just like you would a secondary battery
I read that and I’m still a little bit confused, I don’t want to get an isolator unless I have to and I don’t necessarily want to delete my stock battery so the only option on that website is to wire it straight to the alternator. My question is where would you put the negative then and everything I’ve seen when I’ve looked this up is saying to get a charger for the lithium bank or a battery management system. I don’t really want to spend much more than I already am on building the lithium bank
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
they don"t have anything for the G8, and my problem with the install kit is the hvac part. i dont like the physical controls on it, hard to operate
Not that I like shilling my own sales but I have a badass digital designs 5channel for sale in the classifieds. One of the largest available...
mikeysheff12
mikeysheff12
Hartsville, SC
mikeysheff12
audiobaun
    May 19, 2024
    May 19, 2024
