Do i need to vent an agm?
  • 6
I got a small agm under the hood already...I didn't wanna deal with dueling resting voltages 😂
I'm just waiting on time to free up to mount my 2nd battery. I was telling my uncle what I was doing (and while I'm sure I'm fine) he said I can't mount a battery on the driver's side passenger floorboard without venting. I know with a standard lead acid battery you need some sort of venting, and I'm going agm. He did raise enough of doubt that I'd rather ask the dumb question...do I need to vent an agm in the passenger compartment?
Trunk mounted batteries are vented out of the trunk, so I would think the same would apply to one in the passenger compartment. I know passenger compartment isn't 100% sealed, but some (ie mine) is pretty well sealed. Batteries off gas hydrogen, which could lead to an explosion.
Maybe I'll run up to battery shop on vacation in a couple weeks and see what they can do...they do a lot of fabrication for trucks and farm equipment 😂
114
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
98
434
336
745
spokey9
5 time International Booty Bandit Gold Meldalist
spokey9
NE AR
spokey9
    May 12, 2024
Brendon Jenness
    May 11, 2024
