Door treatment, round 2
  • 1
Water Bear
OK. After that last phail I have been busy.
Cover for door panel
It's just held in with 2 screws to give an idea of how it fits. The opening below it comes with a plastic cover from the factory. That plastic cover and the oddly shaped hole where the crossover is mounted will get treated with MLV when I finally get off my arse and order it.
The panel cover is made out of MDF. I'm not too worried about moisture, so it's going to get 2 coats of a rubberized finish intended for exterior use (patio furnature, etc). When it's dry you can poke it with a screw driver and it won't chip. Currently it's got 1 coat, which is maybe 80% dry. Just wanted to mock it up so I could take a picture. The cover will be sealed against the door with Butyl rope.
I think we're on track to get it right this time; Comments and suggestions welcome.
I finished treating the driver's side door ("left" in the video). I tried to take a video demonstrating the difference. As we all know, phones are really bad at recording low notes so you can't really hear the volume difference. What you can hear is the kind of buzzing sound that the passenger side woofer emits instead of making bass. When you're sitting in the car you can definitely hear a fuller, louder response from the driver's side. There's still some work to be done to that door (coming later) but the treated MDF baffle is more or less finished.
Video
I would do as much as you can afford when you place your new speakers in if you cant do it all now. you can always pull your door panels off later...
478
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
420
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
683
Tons of options in that budget, including the cost of installation,
10
995
Water Bear
Water Bear
Atlanta, GA
Water Bear
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
