TRADE DSP RF 3Sixty.3
  • 1
ThxOne
Premium Member
The Boss
I am willing/wanting to trade my fully functioning RF 3Sixty.3 DSP for a set of 2-way or 3-way components of good quality. 2-way preferred. 6.5" mid.
What you get:
The DSP - The main unit, the remote, the power plug, the high level input plug - (No Bluetooth Dongle)
With the DSP - Non OEM, Shielded CAT7 Ethernet cable for the remote - Long with gold connectors and sleeved in braided black nylon sleeve. OEM is CAT5 non shielded.
With the DSP - Non OEM, Shielded USB cable for connecting to a laptop - Long with gold connectors and sleeved in braided black nylon sleeve.
What do ya got?
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
818
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
633
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
ThxOne
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
