dustcap flew off.....
Liquid Bass
Midwest Militia
3,185
KC Missouri
ok so td i was listening to Dj unk's beatin down yo block, and my dustcap on my mj-18 flew off. i checked to make sure it wasnt hot or anything and it wasnt so im guessing it just had a bad glue job or something, so anyway it still sounds fine, but what kind of glue would be good to put it back on with? thanks in advance:)
no i use that on other things.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
*** is multi purpose, use it. it will hold and while you "bump it" chicks will pick up it's fragrance and will be sexually attracted to you and your equipment.
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
400
6
371
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
Liquid Bass
Midwest Militia
Liquid Bass
KC Missouri
sundownz
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
