eBay Promo 15% off
I was skeptical, but I tried several different amps in the $200 range, from different sellers and it worked on all! PREPSPRING is the codeThank me later!
Make sure to come back and show us your purchase!
Just bought an amp. Thanks.
oh man, need to figure out what I want to pick up... On the 20% code I got the Lanzar Opti 4001d... maybe this time a Taramps HD5000 or 8000.... Decisions... Decisions...
Taramps bass 12k //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
lol jk although if you want to test one (I know, I know, you want budget amps) my truck is in the shop and I could pull it out and send it to you
There are some non budget amps I am testing as well soon.... So I could test your Taramps... Is 11 14V batteries enough for it?
I ended up picking up a Massive Audio BP6000.1 which is their new Full Bridge 3000W amp..
[quote name='bigblank69']There are some non budget amps I am testing as well soon.... So I could test your Taramps... Is 11 14V batteries enough for it?
I ended up picking up a Massive Audio BP6000.1 which is their new Full Bridge 3000W amp..[/QUOTE]
I would imagine so, you may benefit from adding in that 200a power supply I believe I saw you have? or maybe that was barevids or BigD.
Expect current draw of 500-600dca on music. I would be willing to bet it's nearly 1000dca on the 1 ohm uncertified run.
Feel free to message me if you think it's something you'd be willing to try, we can work something out!
@shizzzon any thoughts on 11 14V batteries?
137
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
824
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
beatzboi
beatzboi
United States
wew lad
    May 18, 2024
    May 18, 2024
