Enclosure design. AQ HDC318 (2)
aemeth
15
NW WI
Vehicle: 2004 Jeep Grand Cherokee
Location in vehicle: Rear Hatch area
Space Available: http://wjjeeps.com/i..._area_dimen.jpg
Width: 40"
Depth:30" (up to 32" possible)
Height: Up to 35" (at 25" though I cant see out of the back window, should I just wall it at this point?)
Subwoofer make and Model: Audioque HDC318 http://www.soundqube...oofer_p_25.html
Subwoofer Size: 18 inch
Number of Subwoofers: 2
Type of port: Slot Port
Type of music I like: Mainly rap and rock
Tuning freq: 38 hz (found this to be best in my research for these subs)
Volume: Open to ideas
Amp: 2 AQ2200d's strapped @ 1 ohm
This is what AQ has said to me in an email:
15.56^ft Gross internal volume 180sq inch port at 30" long. Tunes you at 33hz. This is also the smallest inclosure we recommend.
Questions: Im researching how to design my own box but i figured I would start this up right now. In the end I will need a cut sheet, a drawing would be a huge help also.
i did 6cubes each tuned to 32 around 72inches of port area and it got nasty and sounded great but alot of people say go with more port area... I dunno check my vid if ya get bored and see for yourself Iloveaudio87 all one word on youtube
Got some actual maximum dimensions other just 33 inches high? The link to dimensions you posted isn't working for me. I am currently working out a box design for one of these myself. I am trying to shoehorn it into a trunk though so at most I am going to see like 5.2 cubes. Not ideal but it models well in win isd so I am going to give it a shot. AQ actually recommended that low of a tuning to you? The only thing I have ever seen out of them is higher tuning like 38-40 hz. I am shooting for 34-35 myself. In win isd it looks like the output would be very peaky with a higher tune like 38-40ish hz. That peak only goes up as enclosure volume increases as well. If thats what you want it could be a good thing but I want mine to stay a bit more musical.
Width: 40"
Height: Up to 35" (after 25" though I cant see out of the back window, should I just wall it at this point?)
And yes that is AQ's cut and pasted response.
Everything I have read however, (and ive read alot) says to have 6-7 cubes per sub, 15 or 16" port per cube and tune it to 38hz
they normally respond better in larger enclosures, but can work in smaller. I've done 2 18's in 10.25^3 net for an Envoy. Did like a 52+ sealed up and played into the upper 20's tuned at 38Hz. Wasn't ideal but got the job done...
I thought about running two 1 inch dowels, top to bottom and side to port side. I am going to run 2 baffles, so will be 1 1/4" thick front.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
711
aemeth
aemeth
NW WI
mlstrass
    May 19, 2024
    May 19, 2024
