enclosure help
  • 2
mrtopnotch561
hello everyone im thinking about building a new enclosure for my 3 re audio *** 10's. i have a 2008 dodge avenger that they are going to go in. I need help on whats a recommended volume and tuning for my enclosure. Im looking for a ground pounder enclosure that kills the lows. I mainly listen to rap and r&b if that is any help. I have a enclosure now thats 34x14x18 and i practically had to pound it in my trunk lol.. the width needs to stay around 34 the height can be shorter no taller but the depth can be a lot higher if needed. any help is appreciated. thanks
//content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif
---------- Post added at 02:51 PM ---------- Previous post was at 02:51 PM ----------
I can help you.
how is that good sir? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I can help you.
I used BASS Box Pro. It’s what parts express uses on most all their woofer spec recommends. I didn’t build the box phisically that is. I also...
9
Just remember when you pick a tuning frequency as you go higher the box gains efficiency, but loses low end and tends to become peaky.
Here’s another idea I was thinking of. I’m doing a single 12 in the center of the box just for aesthetics I was wanting ports on the sides of the...
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
7
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
mrtopnotch561
mrtopnotch561
west palm beach, fl
mrtopnotch561
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
