Engine Cleaning Tips
ExS
eXcess
1,060
Ok this is what I will do to clean my car's engine.
Spray the engine with a degreser, and let it sit for 15 min, then rinse with water and let dry.
I will be using this:
So is my way good?
my first car was caked when i bought it i soaked it with easy-off and drove it down to the car wash and sprayed it off it was beautiful after that.
What is that?
it's a little handheld steamer that is usually used for cleaning grills and other things (housewife types use it for cleaning showers and other useless stuff), but it cuts through brakedust and engine grime like a CHAMP.
Is it safe to wash my motor with a power wash? I have always heard it was unsafe because of all the electrical (fuel injected)
if you have an intercooler, don't think of putting any water source near it. not because the water will damage it, but any moderate pressure WILL bend the fins beyond recognition.
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
3K
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
3K
ExS
eXcess
ExS
PV Audio
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
