CarOddYo
Got around to installing my planet audio peq10 today and ran the wires through the truck to complete install. I got everything hooked up, peq10 and amp started up, however there is very little sound. And when using the aux to my iPod or sansa clip, there is almost 0 sound.
Setup:
Ppi 4 ohm tweeters
Dayton 4 ohm 5.25 speakers
Planet audio peq10
Soundstream nano Picasso 320.4
I had the speakers setup to be bridged with my dual 2 ohm sub, so the speakers all get one bridged channel (4x4ohm speakers- 4 ohm load) and the d2 ohm sub bridged at 4 ohm on other channel.
I am using a regular line out converter to send a signal from stock radio, just to use the stock radio interface. The eq had inputs for aux and radio, and outputs for sub, front, and rear. Now I have the front RCA on the front input for amp, and sub output on eq on the rear output for the amp. I was testing the rear amp speaker terminals and it appeared they had almost no noise. Switching it around a bit between speaker outputs on the amp I did get some sound but only with the radio. Using MP3 player didn't seem to work at all.
Anyone have any suggestions to try?
Setup:
Ppi 4 ohm tweeters
Planet audio peq10
