right....how about you toss my salad? you're obviously only "knowledgable" in ricer parts where a monkey can install every part. my install required removal of a fuse box and the battery (of course they were put back in place) and a 3.25" hole to be drilled in the chassis...would you like pictures? honestly, if you had my car and did the install yourself, you'd probably:if it took you 3 hours it was because of you! not the install itself
3 hours w/ b pipe but b pipe took
psh, I **** faster than that.
I coulda done it in 2, with spare time to masterbate.
Just about everyone can pooh faster than that //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gifpsh, I **** faster than that.
Let's try this again since you didn't get the point the first time....lmao @ you youngin
honestly, id never work on your car, cuz its not worth my time, so id automatcally loose the wager.if i had to do this all over again i'd love to make a little wager with you to see how long it takes. i'd put a hundred dollars you couldnt do it in 3 hours by yourself the first time
i don't care what kind of mechanical background anyone has, even for someone that's done this numerous times, it still takes at least 2 hours..
not worth my time LOL don't even try to get arrogant with mehonestly, id never work on your car, cuz its not worth my time, so id automatcally loose the wager.
you wanna wager who can swap a turbo faster? or change injectors?
