Exterior Ports? Calculation
  • 2
AndyGiff
CarAudio.com Recruit
Hi everyone! I was wondering since the calculation of determining the port of your enclosure includes the port displacement on the interior space etc, is there a different formula for calculating a port for the exterior of the enclosure? I figured since there would be more available volume inside the enclosure but cant find anything on it. Or do you just add in the volume of the port to the interior volume of the enclosure when calculating it? I would normally use a "port calculator" for this but since I was looking at an exterior port is there something different you need to do when calculating it? I tried searching around for an answer but I am just seeing the normal port calculators etc. If anyone knows please fill me in or if you have a link that can explain the differences in calculation that would be great as well!
Ty guys!
The late 80's early 90's car's OEM speakers were of the same quality as today's offerings. The main difference was the rear speakers were enclosed...
10
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
12
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
AndyGiff
AndyGiff
Fredericksburg, Virginia
AndyGiff
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
