Factory Bose wiring diagram
If your just hooking up a sub (you only need one connection) then use the stock sub wires
If there isn’t a dedicated box in the trunk then there should be a sub mounted in the middle of the back deck lid
Multi meter will give you polarity
If it was me I would disconnect it but you can just splice into it if you want to keep the stock sub in play
I’m hooking up 2 ds18 subs to one amp and 2 other amps for the highs (8 6x9 ) speakers)
I have a 2022 Cadillac with a factory Bose amp. I am in need of a wiring diagram to connect a hi lo convertor to the speaker wires
As new as that vehicle is, there should be no reason WHY you couldnt contact a Chevrolet dealership or contact GM and get a diagram.??
My vehicle also has Bose as the premium option. The same thing was said about climate control for the RX 8. A previous owner replaced the HU...
@1aespinoza I see, so this audio volume leveling is what I was experiencing tapping into the Bose sub wires. Well then, I'm off to check out the...
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
AntonioT
AntonioT
Riverside
audiobaun
